HydroShift II OLED Curved: Lian Li AIOs with curved screens
At last year’s computex, the Lian Li stand gave us a brief glimpse of an AIO with a motorized screen allowing its position to be adjusted. This kit now appears to be available from the brand, which is launching its HydroShift II Oled Curved. It comes with a 360 mm heatsink, while several fans are offered as standard. There’s even a fanless version, so you can choose your own ventilation.
HydroShift II OLED Curved: a Lian Li AIO with curved OLED screen!
A motorized screen :
The special feature of this AIO is its screen. The kit features a well-defined OLED screen with a resolution of 2288×1048 pixels. Size-wise, it boasts a diagonal measurement of 6.67″, while the whole unit is mounted on a motorized system allowing adjustment of its height (in the vertical direction) and inclination. This allows optimum screen adjustment.
Of course, you can display whatever you like on the screen, between system information or moving or still images, there’s plenty to do.
Features :
On the features side, we’re talking about an aluminum radiator that measures just 24 mm thick. It’s beautifully finished with Lian Li-badged brushed aluminum side plates.
When it comes to ventilation, you can choose between the 360P28 version, with fans focusing primarily on airflow, and the 360TL version, with fans featuring an infinite depth RGB effect on the sides.
The P28 model features 28 mm-thick fans operating from 0 to 3000 rpm. Airflow is consistent: 104.8 CFM, while static pressure rises to 7.44 mmH2O. In contrast, the TL version also has 28 mm fans, but they are slower: from 200 to 2600 rpm. Here, airflow is less impressive at 90.1 CFM, and its static pressure falls back to 3.97 mmH2O.
Prices :
Finally, we’d like to finish off with the retail prices, which show off a hefty bill: €339.99 for the TL version, €299.99 for the P28 model and €279.99 for the model without fan.
Here’s the Lian Li product sheet!
