Heaven: a Xigmatek case with curved glass
Xigmatek has released a new case model called Heaven. With this case, the brand has announced a model that adopts an aquarium design, with a compartmentalized chassis and a curved side panel that extends to the front.
Heaven: a new case for Xigmatek!
Xigmatek Heaven
With this new case, Xigmatek is announcing a rather imposing new model with dimensions of 285 (W) x 445 (D) x 486 (H) mm. It is a case that can accommodate E-ATX (272 mm wide), ATX, micro-ATX, and mini-ITX motherboards. Of course, backpanel models are also supported in their ATX and micro-ATX formats.
For other components, note that the height restriction for the CPU cooler is 165 mm, compared to 410 mm in length for the graphics card and 220 mm in depth for the power supply.
In terms of ventilation, the case offers eight slots for 120 mm fans. Three are located on the side of the motherboard and three at the bottom, mounted on a support that can be tilted from 10 to 20°. The last two are located at the rear. However, there is no fan support at the top.
Xigmatek Heaven
This inevitably has an impact on watercooling radiator support, with compatibility with 360 mm models on the side of the motherboard.
In the meantime, the case offers some interesting options. These include an integrated graphics card bracket and a tilting bracket for the bottom fans. Vertical mounting for the graphics card is also possible thanks to an integrated bracket, but the riser must be purchased separately. Finally, you can count on full dust filtration and cool RGB effects.
The price is not yet known!
Check out the Xigmatek product page here!
