HAVN launches BF 360 and BF 360 Flow enclosures
HAVN announces the arrival of two new cases, the BF 360 and BF 360 Flow. With these two cases, the brand offers medium-tower format references, one of which benefits from two 180 mm fans mounted on the front panel. What’s more, the front panel features a stone-effect texture. In short, there’s a lot to say.
HAVN offers its BF 360 and BF 360 Flow!
HAVN BF 360 Flow
With these cases, the brand unveils two references in medium-tower format. Dimensions are 254 (W) x 515 (D) x 522.6 (H) mm. Weight-wise, it’s a hefty 13.6 kg.
Internally this translates into a capacity to accommodate 277 mm wide E-ATX motherboards. On the graphics card side, it will be possible to mount GPUs 410 mm in length. As for the power supply, we’re talking about a 200 mm-deep block support, as opposed to 195 mm-high CPU fans.
As for ventilation, we’re talking about up to seven fan slots, three in 120 mm on the front and top, and one on the rear. Up to five 140 mm fans and four 180 mm fans can also be fitted for maximum airflow. Note that the power supply cover features a deflector to redirect airflow from the front panel towards the graphics card. What’s more, the Flow version comes with three fans, two 180 mm on the front and one 120 mm on the rear.
Otherwise, these cases are distinguished by their imitation-stone facade. Inside, you can also count on a graphics card holder that can be adjusted for height, depth, etc., while the top part is removable.
As for prices, expect to pay $159.99 for the basic version, and $189.99 for the Flow version. There is no extra charge for the white color.
Here are the HAVN product sheets!
