Just like Corsair, Cooler Master also announces a new high-end case. This time, this model belongs to the HAF series which we recently talked about with the HAF500. The model in question is the HAF 700 Evo and has a crazy look with an original interior.
HAF 700 Evo: an original and crazy case!
With this new HAF, Cooler Master offers us a rather crazy medium tower case. From a design point of view already, it will not go unnoticed, especially with these vertical RGB diffusers. Inside, the brand tries to be compartmentalized with a power supply unit that fits behind the motherboard tray. Despite this, this model is not that wide: 294 mm maximum.
Internally, there is also room for the motherboard, which can easily be upgraded to E-ATX format. For the graphics card, clearly, no panic to have with 400 mm of length available. The same goes for the ATX power supply and its 200 mm length or the CPU cooling unit in 160 mm.
However, considering the capacity of the watercooling radiators, it would be a shame to stay with aircooling. Cooler Master announces a double support in 360 mm at the top (or one of 420 mm). On the front, we can integrate a 420 mm radiator, and the same on the bottom. Finally, next to the motherboard, a 480 mm radiator will fit without difficulty! Clearly a case made for watercooling. Note that in the bottom of this model, we have a tiltable support for mounting a radiator.
For the rest, we will retain the presence of a small LCD screen on the front to display information about its system. If you have large storage needs, don’t worry, we have up to 12 2.5″/3.5″ slots. Finally, a small aRGB HUB is also included.
In short, a very complete, watercooling friendly and above all original model. Nevertheless, all this has a price: nearly 500 € at LDLC, Top Buy and materiel.net !
Here is the Cooler Master datasheet!
