A new motherboard from MaxSun: the H770YTX Terminator. This is an original board in terms of itsE-ITX format. In fact, it’s a reference to the extended mini-ITX format!
H770YTX: an extended ITX motherboard from Maxsun!
The problem with offering a motherboard in mini-ITX format is that you don’t have all the space you need to fit all the connectors you want. With this new model, the Chinese brand announces a reference to the original E-ITX format.
As you can see, its height is limited to 17 cm, while its width is much greater. This additional part features two M.2 slots and two SATA slots. On closer inspection, we can also see that the chipset is offset in this area.
What’s more, the board’s main connectors have migrated to the back of the PCB. In fact, no EPS12V CPU or 24-pin connectors are visible… Nor are the various headers, such as USB 3.0 and 2.0 or the F_PANEL , for example.
Otherwise, the rest of the connectivity features two DDR5 DIMM slots (8000 MT/s) and a single PCIe 5.0 x16. Finally, two other M.2 slots are also present, one under the socket, the other on the rear of the PCB.
In short, a truly original model that will only really fit into a micro-ATX case… Provided you have the additional openings for the connectors that have migrated to the back of the PCB. Price: 899 yuan (approx. €115).
