Glacier C370 blocks and Glacier R260 tank from Phanteks
Phanteks continues to expand its catalog of components for custom watercooling. Today we learn of the launch of two new elements. We have a new tank with the Glacier R260 and a new waterblock with the Glacier C370!
Glacier C370, the new waterblock from Phanteks!
Phanteks Glacier C370With its new waterblocks, Phanteks offers models for Intel and AMD platforms. These are compatible with LGA-1700/1200/115x and AM4/AM5 sockets on the AMD side.
As you can see, two colors are offered, one with a transparent cover and black parts. The other features silver-colored metal parts, while the acrylic areas have a frosted effect.
Otherwise, Phanteks communicates an enlarged micro-wing area to cover the entire CPU. These are 4 mm high, 0.4 mm thick and 0.4 mm apart. All this is machined directly onto a nickel-plated copper base.
Finally, in terms of dimensions, the Intel block is more compact than the one designed for AMD platforms. Its dimensions are 94 (W) x 94 (D) x 31.15 (H) mm, while the AMD version measures 90 (W) x 110 (D) x 18.4 (H) mm.
Glacier R260: a new tank!
Phanteks Glacier R260With the Glacier R260, Phanteks offers a choice of black or white colors. Likewise, the tank can be purchased on its own or in combination with a D5 pump installed as standard. In this case, the pump will deliver 1500 l/h with a water column of 3.9 m.
Otherwise, in terms of dimensions, the tank measures 260 (W) x 117 (D) x 80 (H) mm. All this contributes to a liquid capacity of 275 ml. Construction is based on acrylic for the body and backplate , and aluminum for the mounting bracket . Finally, a Viton seal ensures watertightness.
Otherwise, there are numerous input/output ports to simplify integration into a loop. There are four inputs on the top and bottom, and two outputs on the bottom. Finally, at the very top, there’s a filling port.
Pricing:
We end now with the retail price, which is €89.90 for the Glacier C370CPU waterblock in black. The white version will cost a little more: €99.90. As for the C260 tank, Phanteks announces:
  • 159.90 € for the tank alone in black
  • 239.90 € for the set with pump in black
  • 249.90 € for the set with pump in white!
Phanteks product sheets here and here !
