Galahad Uni Fan: Lian Li officially launches its new AIO!
Just a few days ago one month ago, we talked about the new Galahad Uni Fan watercooling kits from Lian Li. If they are the subject of a new article, it is because the brand is officially launching them.
Galahad Uni Fan: the Lian Li AIOs are officially here!
Lian Li Galahad Uni FanFirst of all, a little reminder about this series. Thus, the brand unveils two sizes of radiators in 240 mm and 360 mm. However, they come in both black and white.
On the pump side, we don’t have much information except the use of a copper base and an MTBF of 70 000 hours. The cover will be customizable with a small cap to place on top to hide or not the brand logo.
However, what we will remember most is the ventilation based on UniFan SL mill. You should know that they are available at the retail sale. In short, on the technical side, we learn that they run from 800 RPM to 1900 RPM. At full throttle, it blows pretty well with 2.54 mmH2O of pressure for an air flow of 58.54 CFM. However, we will retain their system of connection being done directly via a connector integrated into their frame!
Finally, we note that the brand takes special care in the finishing of its kits. The radiator has nice brushed aluminum side plates. On the pump side, it is a nice ring, also in aluminum, which is retained.
As for the official prices in France, they are 159,90 € for the 240 mm against 189,90 € for the 360 mm. Prices a little above the average, but we must not forget the finish which looks exemplary!
Here is the technical sheet of Lian Li !
