FSP announces its Hydro Ti Pro power supplies sold for $300 and $350!
At FSP, we find two new power supplies, clearly high-end. The brand unveils its Hydro Ti Pro blocks, compact models with a large certification. In addition, they are ATX 3.0 compliant and have the necessary power for NVIDIA’s RTX 40.
Hydro Ti Pro: 850W and 1000W power supplies!
FSP Hydro Ti Pro
With its power supplies, the brand puts forward blocks of 850W and 1000W of power. However, they are rather compact references because of their 15 cm depth. They also have a high efficiency thanks to their 80+ Titanium certification, which is 96% at 50% load and 90% at 10% load.
For cooling, we find a 135 mm fan with a semi-passive FDB type bearing. Thus, as long as the load does not reach 50%, it will remain completely off to ensure maximum silence.
Internally, we find the famous Japanese capacitors 450V in 105°C. An internal coating is also applied making the block resistant to humidity (95%), dust and drips. Otherwise, these are models that adopt an LLC topology and have a single 12V rail. As for the protections, we find the OCP, OVP, OPP, SCP and OTP.
Finally, the connector system is entirely modular and the number of connectors is identical on both powers. We find a 24-pin ATX and two EPS12V CPU in 4+4 pins. Concerning the graphics cards, a 12VHPWR and five PCIe 6+2 pins are present. Finally, for the peripherals, we have twelve SATA and four molex.
Nevertheless, the bill will be painful: $299 for the 850W version against $349 for the 1000W version.
Here and there are the FSP datasheets !
