Forkis DDC Ultra : combo pump/block CPU from Raijintek !
Raijintek launches a small novelty with its pump/waterblock CPU combo named Forkis DDC Ultra. It is a combo to connect to your custom watercooling loop integrating a DDC pump.
Forkis DDC Ultra : a pump/waterblock combo signed Raijintek !
Raijintek Forkis DDC UltraWith this new combo, the brand Raijintek offers us a set measuring 80 (W) x 84 (D) x 45 (H) mm. As for the weight, we are facing a model weighing 680g.
This set has a DDC pump with a ceramic bearing. Powered by SATA the pump will operate from 1800 rpm to 4800 rpm. At full speed, it will generate a flow of 750 l/h while the water column will reach 3.8 m. Finally, it will generate a pressure of 21.7 PSI.
In terms of compatibility, there is clearly nothing to worry about. Compatibility is assured for the LGA-1700, LGA-1200, LGA-115x, LGA-1366 and LGA-2000 platforms. In AMD, it will run on AM5, AM4 sockets as well as the old AM3/+ and co. On the other hand, the connection to your custom loop will be done via two G1/4″ threads.
Otherwise, the construction seems rather qualitative with a cover made of high quality POM. And to take care of the appearance, we find a small brushed aluminum matrix signed “RJK” for Raijintek. Finally, the base is made of nickel-plated copper and offers micro-wings covering the entire surface of the base!
It remains only to know the price.
Here is the technical sheet of Raijintek !
