Eiszapfen: white watercooling fittings from Alphacool!
We’re off to the world of custom watercooling with new fittings from Alphacool. The Eiszapfen range is now completely white. The kind of little detail that counts if you want to mount a completely white loop!
Eiszapfen: all-white watercooling connectors!
Alphacool EiszapfenThanks to these new end caps, you can now mount all-white custom watercooling loops… In flexible or rigid tubbing, please. Because yes, these are end fittings for acrylic or brass tubing – classy!
Basically, these end caps now have a special white coating. The purpose of this coating is to prevent chipping over time. What’s more, there’s a little Alphacool logo so you know where it comes from!
This white color applies to several types of mouthpiece:
  • G1/4 male to G1/4 female L-shaped rotating nipples
  • 13 mm HardTube screw-on 90° rotating G1/4 fittings
  • 16 mm HardTube screw-on 90° rotating G1/4 fittings
Finally, Alphacool’s press release specifies that G1/4 male to G1/4 female L-shaped fittings are sold in packs of four.
As for prices, expect to pay around 15 euros for 13 mm and 16 mm connectors, compared with around 30 euros for G1/4 connectors… All directly from the brand’s online boutique.
