Eisbaer Pro Aurora: versions in 280 mm and 420 mm!
The Eisbaer Pro Aurora watercooling kit series from Alphacool is now available in new versions. Indeed, the series of kits now includes models in 280 mm and 420 mm. Alphacool announces a new reference in 3x 140 mm.
Eisbaer Pro Aurora: new versions in 280 mm and 420 mm!
Alphacool Eisbaer Pro Aurora 420 mm These new kits are based on the Pro Aurora series of the brand and therefore take the same basis as the models already released. We can therefore count on the presence of a NexXxos ST 30 radiator entirely in copper for example. The same goes for the pump with a DC-LT 2 running at 2600 RPM and generating a flow rate of 75 l/h for example.
Finally, the biggest change is in the size of the radiators, which now accommodate fans in 140 mm and fans in themselves of course. On this occasion, the brand opts for its Aurora Rise mills in 14 cm rotating from 0 RPM to 2000 RPM. Moreover, it will blow quite hard since we find an air flow of 90.7 m3/h and a static pressure of 2.2 mmH2O.
The other advantage of the series is its modularity, since Alphacool uses its quick coupling system. By means of a specific attachment, another kit can be added, such as the Eiswolf to cool the graphics card. This way, you get a complete system without having to worry about setting up and filling it.
Finally, you should know that this series was originally intended for very large CPUs. Basically, we have compatibility with AMD HEDT sockets and Intel server platforms based on LGA-3647 or LGA-4189. You should also know that compatibility with AM4, LGA-1700 and LGA-1200 sockets is still guaranteed.
We finish with the price which is 182,99 € for the model in 280 mm against 211,99 € for the version in 420 mm.
Go here and here for Alphacool’s technical data sheets!
