DF800 Flux: Mesh and RGB for Antec’s new case!
Antec announces a new case model with the DF800 Flux. A new reference that focuses on airflow with a front panel made of mesh, but also a glass part. Finally, the standard ventilation is very complete without mentioning the low price.
DF800 Flux: Four fans already installed!
Antec DF800 Flux
With this new model, the Californian brand offers us a case already well equipped with fans. Indeed, when it comes out of the box, we can already count on four fans, three RGB in front, one non-luminous in the back. Especially since the control of the fans will be done via a small board. It can manage up to six fans and RGB devices!
Moreover, if the four mills are not enough, you can add more, up to five units distributed in the top and on the power supply cover. Moreover, as far as the watercooling radiator support is concerned, we will be able to go up to 360 mm on the front and on the top.
For the rest, we are dealing with a classic model in mid-tower format. It can accommodate motherboards in ATX, micro-ATX and mini-ITX formats. For storage, up to six slots are present.
Finally, for the rest of the components, we have 175 mm for the heatsink, 405 mm for the GPU and 205 mm for the power supply. In short, enough to build nice configurations.
We finish with the price, rather affordable, since it is around the hundred euros!
Antec’s datasheet is here!
