DeepCool presents its FL12 Series fans!
From DeepCool, we will be highlighting the announcement of new fans with the FL12 series. The latter is designed for case use, while the windmills feature RGB lighting. Likewise, these fans will also be available with inverted blades for an even more polished look!
FL12: 120 mm case fans from DeepCool!
Ventilateurs DeepCool FL12As you can see, these fans benefit from the brand’s typical design, with a square frame and silentblocks of the same shape. Inside, the frame features a light ring illuminated by a total of 36 RGB diodes that can be seen from the sides via transparent sections. If you love RGB galore, this is the fan for you.
Otherwise, it’s built using quality materials. PBT is used here to ensure a long service life. The mills also feature a quick connection via a proprietary eight-pin connector. This connector manages the lighting, power supply and speed.
In terms of features, these windmills have a speed range of between 500 and 2,150 rpm. At full speed, airflow reaches 55 CFM, while static pressure rises to 2.82 mmAq.
However, if you want to install fans at the bottom of your case, a version with inverted blades has also been announced. Thanks to the latter, you’ll be able to enjoy maximum performance and a polished look in your case. In addition to the direction of the blades, the characteristics have also changed, with only a tiny variation in static pressure, which has risen to 2.59 mmAq. The speed range and airflow remain unchanged.
All that remains now is to talk about prices. These are officially announced at €21.99 in white or black as a single unit. In a pack of three, the price rises to €62.99. The inverted blade versions will be more expensive: €29.99 individually, €79.99 in a pack of three.
Availability will start tomorrow, with inverted blades available from March 25.
Here are the DeepCool product sheets!
