DeepCool announces its µATX CC360 aRGB box at €54.99!
Starting in June (although it’s already available, in fact), you’ll be able to purchase a new case from DeepCool. The brand is unveiling its CC360 ARGB, an affordable µATX model priced at €54.99.
CC360 ARGB: a small DeepCool case!
DeepCool CC360 aRGBWith this model, the brand is obviously offering a compact case, as it is designed to accommodate a µATX motherboard. Dimensions are 215 (W) x 418 (D) x 431 (H) mm. In view of its reduced size, the weight is also reduced, to 4.9 kg.
Internally, this model allows the mounting of a 165 mm ventirad, which is quite comfortable. The same goes for the graphics card, with 320 mm. However, for the power supply, this reference limits the size of the block to 160 mm in depth.
As for storage, it’s classic compatibility with two 2.5″ and two 3.5″ slots.
In terms of cooling, this case comes standard with three fans, two 120 mm fans on the front and rear. If required, the ventilation can be completed by adding up to three additional fans: one on the front, two on the top. Given the format, compatibility with watercooling radiators will be limited to models with a maximum front panel diameter of 280 mm.
As for prices, you’ll have to officially reckon with €54.99 in black or white…
