CR-1400 DV2: a 92 mm dual-tower ventirad from Jonsbo
The Jonsbo brand has come up with a new ventirad for cooling our processors. It’s a double-tower model, BUT in an ultra-compact format. To reduce overall dimensions, the brand has opted for 92 mm fans.
CR-1400 DV2: double-tower air cooling in 92 mm from Jonsbo!
Jonsbo CR-1400 DV2With this model, Jonsbo offers us a heatsink in double-tower format. However, it features two 92 mm fans. The aim is to reduce the footprint with space-saving fans, so as to reduce the height and width of the heatsink. This translates into dimensions of 92 (W) x 144 (D) x 136 (H) mm.
The structure is therefore familiar, with two stacks of aluminum fins. These are crossed by a total of six copper heat pipes, each 6 mm in diameter, and meet at the base. However, they will come into direct contact with the CPU.
Jonsbo CR-1400 DV2
The two fans will operate at up to 2300 rpm. At full speed, airflow will reach 38.2 CFM, while static pressure will rise to 2.0 mmH2O.
Finally, as you can see, RGB is very (too?) present. It can be found on the fans (blades and hub) as well as on the top of the radiator with covers present on the top of the towers with infinite depth effects.
Price still to be determined!
Jonsbo product sheets here and here !
