COUGAR Fobos 150: to the point!
COUGAR Fobos 150: we have two ranges in our catalogs: gaming and creator. Today, it’s the gaming range that gets a new product with the Fobos 150 desk. This is a basic model that will suit everyone. It can simply be used as a desk.
COUGAR FOBOS 150
COUGAR FOBOS 150
Introducing COUGAR FOBOS
Here we have a desk in its purest form. In other words, no motorization to change height, for example. Nor are there any RGB or HUN USB functions. It consists of a 1500 x 769 mm MDF board on two legs. There’s a 22 mm cutout at the rear. This makes it easy to hide screen cables, for example. The front has a small bevel cut and a chamfer cut.
COUGAR FOBOS 150
COUGAR FOBOS 150
The main features of the COUGAR Fobos 150 :
  • Desk width x depth (mm ): 1500 x 769
  • Height (mm ): 763
  • Desk material: MDF, medium-density fiberboard
  • Desk surface: scratch-resistant, frosted black
  • Concave and cable tray organization: yes
  • Front ergonomics: Chamfered and curved
  • LED effects: no
  • I/O control box: no
  • Weight tolerance (kg ): 80 kg
  • Total weight (kg ): 28.5 kg
  • Packaging dimensions (mm ) : 1572 x 848 x 145
For further information: click here. No price or release date yet.
