Corsair’s AIO iCUE Link with LCD screen!
Corsair’s iCUE Link series of watercooling kits is completed with the arrival of AIOs now incorporating an LCD screen. As a reminder, this series has the particularity of offering a very reduced number of cables, thanks to the serial connection of each component making up the AIO.
iCUE Link, Corsair’s kits now feature an LCD screen!
Corsair iCUE Link LCDAs a reminder, Corsair’s kits feature ultra-limited connectivity. Indeed, via a single controller, Corsair proposes to control every element of the AIO, be it the fans, the pump, the lighting or even their speed. Corsair also adds a customizable 2.1″ IPS LCD screen. To see what you can do with it, we invite you to read our article on the H170i Elite LCD XT.
There, the series comes in three radiator sizes, with kits in 240 mm (H100i), 360 mm (H150i) and 420 mm (H170i). As for color, the H150i will be available in white, but not in black.
As for ventilation, there are two or three 120 mm or 140 mm fans, depending on radiator size. If the need arises, they can climb up the towers with maximum speeds of 2400 rpm in 120 mm and 2000 rpm in 140 mm. On the other hand, they offer a 0 RPM mode for those allergic to noise.
Once again, the H100i is priced at ~€335, compared with ~€380 for the H150i and ~€415 for the H170i. At this price, you might as well opt for custom watercooling, which is also offered by Corsair. For the moment, commercial availability does not appear to be effective.
Here are the Corsair product sheets!
