Cooler Master unveils a new case reference and updates its NR200P with the NR200P V3. Larger in size, this new version enhances graphics card support in a highly elegant manner. What’s more, the choice of materials has been improved with the addition of aluminum.
NR200P V3: an improved version of the NR200P!
In terms of dimensions, the case is slightly longer: 378.2 mm vs. 372 mm for the V2. Otherwise, width and height remain unchanged: 185 x 292 mm. Internally, this is still a case compatible only with mini-ITX motherboards. So don’t expect much space. Nevertheless, the brand does allow the mounting of large 36.5 mm graphics cards, all vertically. We also note the presence of a PCIe 5.0 x16 riser for connection to the motherboard. What’s more, in front of the graphics card, we find a mesh view to let the ventilation breathe.
For CPU cooling, if you opt for an air cooling heatsink, compatibility will inevitably be limited: 70 mm in height. However, you can compensate for this limited space with watercooling in the form of an AIO, with a 240 or even 280 mm model at the top of the chassis. The ventilation can accommodate four fans, two 120/140 mm at the top. At the bottom, due to the positioning of the graphics card, we are limited to 120 mm by 15 mm. It should be noted that one of the two fans can be replaced by a hard disk, for example. Finally, the control panel features two USB-A units coupled with a 20 Gbps USB-C . For the moment, we don’t know the retail price.
Here’s the Cooler Master product sheet!
