Cooler Master launches its Mobius 120 OC fan!
Cooler Master launches its new Mobius 120 OC fan. This is a new high-end mill that was initially introduced at CES earlier this year. Plus, the good news, it’s available in stores!
Mobius 120 OC: Cooler Master launches its new high-end fan!
Cooler Master Mobius 120 OC
With this new fan, the brand offers us a 120 mm mill a little thicker than usual: 27 mm.
Via a speed selector located on the power cable, we can select three speed profiles. If you want silence, you will choose the 1200 rpm, if you want to go a little further, you will switch to 2400 rpm and if you want a maximum performance, you will switch to 3200 rpm. Moreover, this will have an impact on the air flow and the static pressure which are the following:
  • 1200 rpm: air flow → 42.2 CFM and static pressure → 1.19 mmH2O
  • 2400 rpm: airflow → 65.5 CFM and static pressure → 2.76 mmH2O
  • 3200 rpm: airflow → 88.1 CFM and static pressure → 4.75 mmH2O
Finally, we will note that this fan has a double ball bearing and the motor is reinforced. Ditto for the blades, connected to each other via an internal ring. Let’s not forget to tell you about the rubberized silentblocks present at the four corners.
On the price side, the bill will be quite high: 29.90 € unit.
