Cooler Master announces its TD500 Max enclosure
Cooler Master announces its new TD500 Max case. The Max series is now available in ATX format. But what is this series? Quite simply, it’s a series of cases with a power supply and cooling system installed as standard.
TD500 Max: standard power supply and AIO!
Cooler Master TD500 Max
Like the NR200P Max, this model benefits from a number of standard components. First and foremost is the 850W GXII Gold power supply. What’s more, the connectivity is pre-wired, with ATX 24-pin, EPS12V CPU and PCIe connectors already routed. All that’s left to do is plug them into your components. What’s more, cabling is on two levels, with female connectors at the various cable entry points. The aim is to limit stress on the cables.
A liquid cooling system is also included. For the occasion, we find a customized AIO Atmos with a 360 mm radiator 38 mm thick. This is topped by Mobius 120P fans.
Turning now to its technical data sheet, we learn that this case measures 210 (W) x 499 (D) x 500 (H) mm, while offering a volume of 48l.
Internally, we’ll be able to install ATX motherboards coupled with :
  • Graphics card: 380 mm long
  • CPU cooling unit: 165 mm high
As for storage, there are two 3.5″ slots coupled with three 2.5″ slots.
As for ventilation, three 120 mm fans can be fitted at the top, on the front and a small one at the rear.
No price yet.
Here’s the Cooler Master product sheet!
