CMP 510: a mid-range Cooler Master case!
New case for Cooler Master which announces its CMP 510, a new mid-range reference. To distinguish itself, the brand counts on an asymmetrical front panel, mesh and RGB!
CMP 510: an asymmetrical design for Cooler Master ‘s case!
Cooler Master CMP 510So, we find a case with a medium tower format. This last one displays quite compact dimensions of 204 (W) x 445 (D) x 463 (H) mm. As you can see, internally, we have room to install an ATX format motherboard. The graphics card has seven expansion slots (to be removed) and a maximum of 350 mm of space. Finally, concerning the power supply, we have 160 mm of depth against 161 mm for the ventirad. The storage part remains quite standard with four slots. In detail, the case benefits from an HDD cage with two 3.5″/2.5″ baskets and two slots dedicated to 2.5″ units. For liquid cooling, the brand announces a support for radiators in 280 mm maximum in front. Otherwise, for ventilation, we have three slots in 120 mm in the front, two in the top and one in the rear. In short, this case should breathe quite well thanks to its asymmetrical front featuring a mesh part. The same goes for the power supply cover, which has a perforated part to let your block breathe a little. Otherwise, an RGB border is part of the front, as well as three bright fans in 120 mm. For the price, Cooler Master announces its new model at 89.99 €, which places it in the mid-range segment!
This way to the Cooler Master datasheet!
