CL6600: DeepCool launches its compartmentalized enclosure
DeepCool’s CL6600 is a case we first discovered at Computex this year, on the brand’s stand. This innovative model features a compartment dedicated 100% to liquid cooling on top, while the rest of the configuration is housed in another compartment. If we’re talking about it again today, it’s because the brand has just launched it!
CL6600: DeepCool’s compartmentalized case launched!
DeepCool CL6600The dimensions of this case are 235 (W) x 457.5 (D) x 533.5 (H) mm. It weighs in at 11.82 kg.
Internally, this reference is compatible with backpanel motherboards in ATX, micro-ATX and mini-ITX formats. The graphics card can measure up to 413 mm in length, or 388 mm with front-mounted fans. Finally, for the CPU ventirad, we have a clearance of 175 mm in height and 160 mm for the power supply.
Of course, the special feature of this case is that it comes directly with a 360 mm watercooling kit mounted in the top compartment. This means there’s no need for a cooling system when purchasing this model.
Otherwise, as far as ventilation is concerned, this model comes with two 120 mm mills mounted in the bottom intake. However, if you wish, you can add a 120/140 mm grinder at the rear and two 140 mm grinders at the front.
Last but not least, this is a model that benefits from a dedicated headphone support, and the same goes for the graphics card. Cabling is facilitated by Velcro straps, while the panels benefit from a push-pin system to hold them in place.
Officially, prices are $179 in black and $189.99 in white.
Here’s the DeepCool product sheet!
