CH560 Digital: DeepCool enclosures available with and without screens!
A new case from DeepCool: the CH560 Digital. This new reference should offer good airflow thanks to its mesh front panel. It will also be available in a non-digital version, without LCD screen.
CH560 Digital: a new DeepCool case with LCD display!
DeepCool CH560 DigitalWith these new cases, the Chinese brand presents a new case in mid-tower format. This translates into dimensions of 230 (W) x 458 (D) x 471 (H) mm and a weight of 7.7 kg.
Internally, there’s plenty of space for a motherboard in E-ATX format. On the GPU side, clearance is 380 mm long, while the CPU cooler is 175 mm high. Of course, the power supply will be in ATX PS2 format, with 170 mm of free depth.
As standard, the fan comes with four pre-installed aRGB fans. Three of these, in 140 mm, are front-mounted, while the last in 120 mm is rear-mounted. If required, three 120 mm or two 140 mm fans can be added at the top. As for the watercooling radiators, compatibility with 360 mm models is assured at the top and front.
Of course, the special feature here is a small LCD screen positioned on the side. This will be used to display information relating to the CPU and GPU. You’ll be able to keep an eye on the temperature and usage of the processor or graphics card.
Finally, pricing remains rather affordable, at $119.99 in black with display, versus $129.99 in white, again with display. Without the digital display, the price drops to $99.99 in black and $109.99 in white.
Here are DeepCool’s product sheets!
