[CES 2024] Yeyian presents a 480 mm AIO watercooling kit!
As CPU TDPs rise, cooling solutions are also on the increase. Initially, if we had a 280 mm kit, it wasn’t bad! Then 360 mm kits came out, followed a few years later by 420 mm AIOs. This year, on its stand at CES, the Yeyian brand is presenting a 480 mm all-in-one kit!
Yeyian presents a 480 mm AIO at CES!
Yeyian AIO 480 mmAs you can see, this 480 mm radiator can accommodate up to four 120 mm fans per side. Impressive though this is, it does pose one major problem: you’ll need a compatible case. Clearly, it’s hard enough to find 420 mm-compatible cases (although this is improving with time), but there must be a 480 mm-compatible case out there… Three on the market?
As for the pump, we obviously don’t know its specifications, but we do know that it has a 2.1″ IPS LCD screen. And as usual, it’s capable of displaying lots of pretty things.
Finally, we’d like to mention a series of very imposing kits featuring 360 mm, 420 mm and 480 mm radiators for the model on display.
Finally, we wonder about the relevance of offering such a large radiator in an AIO. Indeed, this requires a special, often very high-end enclosure. So rather than installing an AIO in a €400 case, wouldn’t the user be more tempted to fit a custom watercooler ? Ditto the question of the pump, since to circulate the liquid in there, it needs to be at least powerful, capable of ensuring a minimum flow rate, which is not always the case with AIOs.
