Blizzard SP Series : two watercooling kits for Azza !
The brand Azza announces the arrival of two new watercooling kits with its Blizzard SP Series. In broad outline, we find kits in 240 mm and 360 mm, all with a massive use of RGB. If you like discreet kits, perhaps it is better to pass.
Blizzard SP Series: AIOs that are anything but discreet!
Azza Blizzard SP Series
As you can see, the brand clearly emphasizes the RGB lighting that is present at all levels. So we have lights on the fans as well as on the pump. Moreover, the latter displays an infinite depth lighting similar to what we can find on the NZXT kits.
Concerning the dimensions, these two AIOs are 240 mm and 360 mm, rather common dimensions shall we say. Regarding the thickness, the dimensions are not specified, but we can expect 27 mm with an aluminum construction.
In terms of fans, we will have the right to two or three Hurricane SP Digital mills. These take advantage of a PWM power supply and will operate from 700 RPM to 2200 RPM at full speed. Unfortunately, the rest of their features are not yet known.
Finally, we end with the selling price which is 99 € in 240 mm and 129 € in 360 mm. Yes, the prices are quite affordable, we just have to see what it will give from a temperature and noise point of view.
