B1 Pure: a white In Win case with a wooden panel!
This time, we go to the world of ultra-compact cameras with In Win. The brand announces its B1 Pure, a new variation of the original B1. The main difference? Its full white color and its wooden side panel!
B1 Pure : a case on an In Win case !
In Win B1 Pure
With this model, we find the philosophy of the original case to know a compact size and an attractive design. Speaking of size, this model has dimensions of 108 (W) x 238 (D) x 305 (H) mm. The weight, inevitably, will be very contained with 1.65 kg.
Now that we’ve said that, you can imagine that the motherboard will be limited to the mini-ITX format. The same goes for the CPU fans, which will only be 60 mm high. We might as well tell you that the NH-L9i and NH-L9a from Noctua will be out. Ditto, no room for dedicated GPU, there, we will have to turn to processors with iGPU … Basically, Ryzen G and Core i.
Otherwise, the brand provides a power supply in Flex-ATX format with a power of 200W. On the efficiency side, we have an 80+ Gold certification. Be careful not to be too greedy with the CPU part. In Win warns: no Core i in 8 cores and more, it is the blow to overload the system.
We finish quickly with the storage part which puts forward two 2.5″ slots on the back of the motherboard tray. Of course, you will have to count these slots in addition to the M.2 present on the motherboard.
Finally, we finish with the selling price of this small case. Apparently, it will cost 115€.
Here is the technical sheet of In Win!
