The brand Alphacool, specialized in the world of custom watercooling, announces the arrival of a new accessory for your PC. Indeed, thanks to its Aurora Vertical GPU Mount, you will be able to install your card in this way in your case. An interesting accessory if you don’t have a vertical slot in your case… Or if they are too close to the side window!
Aurora Vertical GPU Mount: a vertical and RGB GPU support!
The purpose of this type of accessory is to be able to mount your graphics card vertically in a case where this is not possible. Or to move the graphics card away from the side panel to give it a little more room to breathe. It’s true that a card whose fans are stuck to the side panel is not ideal for cooling.
Anyway, this accessory will be fixed on the expansion slots of your case, six to be more precise. So you won’t need a PCIe to plug in a WiFi card or an M.2 expansion card for example.
Otherwise, this support is intended for double slot graphics cards, so you won’t be able to install triple slot monsters. It should also be noted that the PCIe riser is supplied as standard. Moreover, it is a PCIe x16 3.0 type cable with a length of 25 cm. Finally, you should know that an aRGB lighting is part of the game via a total of 11 individually addressable diodes!
For the price, it will be 71.98 € on the store Alphacool directly!
This way to the Alphacool datasheet!
