Assassin 120 SE White: Thermalright Dual Tower Heatsink
In October 2021, the brand Thermalright announced its Assassin 120 dual tower heatsink. Now, in January 2022, the brand unveils its Assassin 120 White SE, an all white version.
Assassin 120 SE White : an all white ventirad from Thermalright !
Thermalright Assassin 120 SE White The base of this model is already known and for good reason, it is a black model “repainted” in white. There will be no change in dimensions, which are still 125 (W) x 110 (D) x 155 (H) mm without the fans. As for the weight, it reaches 730 g, we imagine without fans too.
The radiator in question has a total of six copper heat pipes of 6 mm each and 50 aluminum fins. White version obliges, all this little world displays a color… White. Finally, the base is slightly off-center to the left so as not to encroach on the first PCIe slot of the motherboard. As for its construction, we have the right to C1100 copper.
The ventilation has two 120mm mills with aRGB lighting. These have a PWM power supply. At full speed, they will rotate up to 1550 RPM and generate an airflow of 66.17 CFM and a static pressure of 1.53 mmH2O.
We end by mentioning AM4, LGA-1100 and LGA-1700 compatibility.
Here is the datasheet of Thermalright !
