ASRock with a White 7900 XTX Taichi !
ASRock offers us a new graphics card. It is a base of AMD and not Intel since we find a RX 7900 XTX Taichi White. A card that, as you can imagine, will be all white … Or almost!
RX 7900 XTX Taichi White : the new big card from ASRock !
RX 7900 XTX Taichi WhiteWith its new card, ASRock offers us an imposing model occupying three slots in a case. Moreover, the heatsink is imposing and long: 345 mm long and 140 mm high. At the same time, we find two 110 mm mills and one 100 mm in the middle. They adopt a semi-passive operation in addition to rotating in opposite directions from each other.
The radiator seems neat and offers two distinct blocks of aluminum fins. A total of eight copper heat pipes run through the whole assembly, which meet at the GPU via a nickel-plated copper base. Finally, the memory has its own heat pipes. To stiffen the whole, ASRock applied a steel frame at the PCB and a backplate.
The board is built around a custom PCB with a total of 22 power phases. They are made of Japanese capacitors, DrMOS and 100A inductors.
With all these means in place, it would have been a shame not to have factory overclocking on arrival. For the time being, this model displays a boost to 2680 MHz against 2500 MHz for the reference card.
All that remains to be seen is how much this model will cost.
Here is the ASRock datasheet !
