Arc Pro B60 DUAL: Sparkle gets in on the act too
Sparkle joins the select club of GPU manufacturers offering Arc Pro B60 dual GPUs. The brand joins Maxsun , which already offered this type of solution… A solution we were able to discover at Computex. In short, Sparkle offers a singular card, since it is passive and adopts a reduced number of video outputs, with two HDMIs positioned in unconventional locations.
Arc Pro B60 Dual: a fanless version from Sparkle!
Sparkle Arc Pro B60 DualThis is a dual-GPU model, with two graphics chips on a single PCB. In addition, the brand has chosen to apply a passive heatsink where no active fan is present. Instead, we’re treated to a heatsink whose fins cover the entire length of the board. Naturally, this type of heatsink predestines the card for server use, mounted in racks with powerful ventilation.
Configuration-wise, it’s no surprise to find two GPUs, each with 20 Xe2 cores and 2,560 shaders. They also feature 160 TMUs and 16 ROPS each. As for memory, there’s 48 GB on the PCB, connected to a 192-bit bus. Naturally, both chips share the PCIe 5.0 x16 interface, while the TDP is 400W.
To power all this, we find a sixteen-pin 12V-2×6 connector on the rear of the board. As for the video outputs, Sparkle has chosen to adopt a single HDMI connector on the PCIe bracket, while a second connector will be present on the card’s edge. All this will support 7680×4320 resolution, all at 60 Hz.
Finally, we learn that the brand plans to launch two other versions of this card. One will be water-cooled, while the second will adopt a blower heatsink.
