Another batch of Eiswolf 2 kits at Alphacool!
Alphacool continues to roll out its Eiswolf 2 kits. As a reminder, these are custom watercooling kits pre-assembled in the form of all-in-one kits. However, unlike the Eisbaer, these kits are intended for graphics cards!
Eiswolf 2: even more GPU kits for Alphacool!
Eiswolf 2 - RTX 4090Alphacool still offers us an assembly based on NexXxos ST30 copper heatsink in 360 mm. The GPU waterblock is still a full cover type with a pump installed directly in the terminal. The pump is DC-LT2 and works at up to 2600 rpm. Finally, the hoses benefit from a quick coupling system that allows the Eiswolf to be coupled to an Eisbaer kit. In this way, a complete CPU/GPU loop can be formed.
With this new batch, the company is focusing on many boards. This concerns both RTX 40 and RX 7000 in AMD.
On the NVIDIA side, we find references compatible with RTX 4090/4080 TUF/OC and Strix/OC. On the MSI side, this will concern the RTX 4080 Gaming X Trio and Suprim X.
As for AMD cards, of course, we have an AIO compatible with RX 7900 XTX reference. Cards from Asus, ASRock, Biostar, Gigabyte, PowerColor and XFX are supported. As for the custom models, we find the 7900 XT/XTX Vapor-X from Sapphire… The same goes for ASRock with support for the RX 7900 XT/XTX Taichi/OC and Phantom Gaming/OC.
As for the price, it will cost about 270 €.
Here are the technical data sheets of Alphacool!
