Another batch of Alphacool Eiswolf 2 AIO for RTX 4080/4090
The series of AIO watercooling kits for graphics cards from Alphacool continues to grow. The brand announces new Eiswolf 2 for many graphics cards. Indeed, models signed Gainward, Zotac, PNY, etc. are now concerned!
Eiswolf 2: always more supported cards!
Eiswolf 2 - RTX 4090Alphacool’s recipe still hasn’t changed. Indeed, the brand still offers us a custom watercooling set pre-assembled. The cooling is provided by a 360 mm NexXxos ST30 radiator and three 120 mm Rise Aura fans. Regarding the pump, it is still a DC-LT2 operating at 2600 rpm. Finally, for the graphics card, we have the right to a full cover waterblock cooling the memory, the GPU and the VRM.
Finally, as for the Eisbaer kits of the brand, we have a quick connection system. Thanks to this, we can connect the CPU and GPU to form a single loop. All that remains is to have a case capable of accommodating two heat sinks, one of which is 360 mm.
As for compatibility, the list is long. This batch of products is therefore aimed at RTX 4080s with a reference PCB. The references concerned are the Inno3D X3, iChill, iChill x3 models. The same goes for PNY with the Gaming Verto Epic-X Triple Fan and OC versions. On the RTX 4090 side, we have a looooooong list here:
  • Founders Edition (NVIDIA)
  • GameRock/OC (Palit)
  • Phantom/GS (Gainward)
  • Gaming OC – Master (Gigabyte)
  • Trinity/OC – AMP Extreme Airo (Zotac)
  • Suprim X – Suprim Liquid – Gaming Trio (MSI)
For the price, it will be necessary to count approximately 270 €, directly from the store of the brand.
Here are the technical data sheets of Alphacool!
