An Alphacool waterblock for Palit GamingPro cards
Another batch of waterblocks from Alphacool, with new references for Palit GamingPro boards. The German brand offers everything needed to watercool the RTX 5080 and RTX 5070 Ti from this series. Of course, these are all blocks from Alphacool’s Core series!
GamingPro, Palit’s RTX 5080 and RTX 5070 Ti watercooled by Alphacool!
Alphacool Core RTX 5080 RTX 5070 Ti
On the menu, we find new full cover water blocks. They cover the entire PCB of the graphics card on which they are mounted. The GPU, power supply stages and memory will be actively cooled. Dimensions: 184.70 (W) x 125.32 (D) x 31.19 (H) mm.
Naturally, the choice of materials here is chromium-plated copper, a treatment deemed more resistant than simple nickel plating by Alphacool. Otherwise, the upper part is acrylic-based, while the terminal is nylon with chrome-plated brass threads. In short, it looks good, all the more so as aRGB diodes are present to generate a very pleasant lighting effect.
As for compatible cards, this new batch takes on Palit’s RTX 5080/5070 Ti offering. Here, Alphacool targets GamingPro models as mentioned above.
All that’s left is to talk about selling prices, which here stand at around €200 on the brand’s own store.
