Aerocool Interstellar: a case with a lot of RGB on the front!
Aerocool launches a new case with its Interstellar. It is a new reference in the medium tower format with a very present luminous lighting on its front face. Otherwise, the case remains classic in its design!
Interstellar: a new Aerocool case that relies on its front RGB!
Aerocool InterstellarWith its new case, the brand announces a medium tower model that measures 210 (W) x 429 (D) x 483 (H) mm.
Inside, there will be enough space to install motherboards in ATX, micro-ATX and mini-ITX formats. But that’s not all, since 362 mm graphics cards, without front fans, will fit. Regarding the ventilator, we have 163 mm free against 186 mm for the power supply.
As for the ventilation, the case has two aRGB fans in the front, two in the top and one in the back. If you want to complete the ventilation, you can only add a third fan on the front. In any case, for watercooling, we can install radiators up to 360 mm in the front and 280 mm in the top.
The storage part relies on a HDD cage with two 3.5″/2.5″ baskets as well as two 2.5″ boards. The latter are present at the back of the motherboard tray.
Finally, there is a fan and RGB hub with five ports for fan management. The control panel will also include a light management button in addition to its two USB 3.0 and its single USB-C.
For prices, you’ll have to look at 1fodiscount and PC21.fr to get an idea. At the first one, the Interstellar is priced at 92,90 € against 83,88 € at the second one.
Here is the technical data sheet of Aerocool !
