With the A4-H2O, we are now going to talk about a really compact case. Indeed, this model is the result of the collaboration between Lian Li and DAN who offer us an ITX model with only 11l of capacity. It’s not much? But wait to see what you can put inside!
A4-H2O: 11l of capacity, a triple slot GPU and an AIO in 240mm!
With this new model, the brands offer us a really compact case of 140 (W) x 326 (D) x 244 (H) mm. Clearly, it is not very big, especially since this model offers a volume of only 11l. The construction is based on aluminum panels and an internal steel structure.
Inside, you will have understood that we will be limited to motherboards in mini-ITX format. The same goes for the power supply: SFX/SFX-L is mandatory. On the other hand, the graphics card will be 322 mm long, all on 3 slots. Clearly, there will be plenty to do in this regard.
For cooling, of course, we will be very limited with two 120 mm fan slots at the top. Nevertheless, it will be possible to install a watercooling radiator in 240 mm. The only constraint is the limited thickness of 55 mm. And if you opt for an aircooling type ventirad, you should not think too big with 55 mm height.
We end briefly with the storage part which is satisfied with two 2.5″ slots at the bottom.
For the price, you will have to count $119,99 for the version with PCIe 3.0 riser and $154,99 for the PCIe 4.0 model.
Here’s the datasheet on Newegg !
