A watercooling tank for 2U servers from Alphacool
Alphacool has a new tank for 2U server racks. With its ES 2U Reservoir VPP, you can benefit from a compact reservoir/pump combo for your rack server.
ES 2U Reservoir VPP: a reservoir/pump for a 2U server rack!
ES 2U Reservoir VPPIn itself, the product is pretty rough around the edges, no frills with pretty finishing touches here. With this product, Alphacool is targeting professional installations and 2U racks in particular.
As you can see, the front of the tank has an inspection window so you can constantly check the liquid level in the system. There are also two sensors for monitoring temperature (-40°C to +125°C) and flow rate.
Otherwise, this is a rather compact unit measuring 99.66 (W) x 146 (D) x 83.9 (D) mm. Not surprisingly, this little thing weighs in at a hefty 1.5 kg on the scales, while the construction combines metal and acetal.
As for the ports, there are two on the front in G1/4″ with quick release for refuelling. At the rear, there are two other G1/4″ ports for input and output.
For the price, expect to pay €199.98 at the brand’s shop!
