A new graphics card from ASRock, which now includes an Intel Pro B60 24GB in its Creator range. Naturally, we’re dealing with a blower-type card with compact dimensions to fit into a large number of PC cases. With this model, we typically have a card for AI in particular.
Pro B60 24 GB: an ASRock card for the professional sector!
This is a classic professional graphics card equipped with a blower type cooling. For this type of application, the blower is the ideal solution, as it allows the cooling of several graphics cards in a single system. The fan is not muffled by the card underneath, as would be the case with a cooling system equipped with several axial fans. In terms of dimensions, the card is rather compact, measuring 271 mm in length, 112 mm in height and 39 mm in thickness. It therefore adopts a strict dual-slot format, a format appreciated by professionals for their workstations. As for the GPU, we find a board equipped with a GPU equivalent to that of the B580, featuring 20 core Xe2 with 2,560 shaders. It also boasts 160 tensor cores and 20 RT cores. However, the memory is more substantial, with not 12 GB but 24 GB of VRAM coupled to a 192-bit bus. Thanks to 19 Gbps of memory, bandwidth is 456 GB/s. As for the GPU, it spins at 2400 MHz! Video outputs consist of four DisplayPort 2.1s, one of which supports UHBR 13.5, while the other three support UHBR10. As for the power supply, a single 8-pin PCIe is present. Its positioning is not explained, but we can expect it to be located at the rear of the board. Now the big question will be the selling price, which is not yet known.
Here’s the ASRock product sheet!
