3090 Ti Gallardo : Manli announce a card !
This time we go to the other side of the world with the brand Manli. Indeed, the Asian manufacturer also announces its RTX 3090 Ti Gallardo. This is a custom and overclocked factory model.
3090 Ti Gallardo: what does the card from Manli look like?
Manli RTX 3090 Ti GallardoWith this model, Manli offers us an imposing card with a heatsink consisting of three fans. Two of them are 100 mm while the middle one is smaller: 90 mm. The heatsink is also imposing with two blocks of aluminum fins and seven copper heat pipes of 8 mm each. Finally, a backplate is present to stiffen the board.
The PCB of the card will be very short and for good reason, the brand uses the reference PCB from NVIDIA. In fact, the card benefits from a total of 18 + 3 power supply phases.
As we said, the card is overclocked from the factory, however, this overclocking is far from being consistent. This model displays a boost to 1875 MHz instead of 1860 MHz for the reference card.
As far as connectivity is concerned, we are entitled to a total of three DisplayPort and a single HDMI. Two NVLINK connectors are also present on the slice, as well as the 12+4 pin PCIe power connector.
Manli’s datasheet is here!
