3060 Ti AMP White Edition: Zotac brings us a white RTX card!
From Zotac, we can count on the arrival of the RTX 3060 Ti AMP White Edition. As the name suggests, the card is completely white, but also compact. In short, what it all looks like!
3060 Ti AMP White: a compact and all white card!
Zotac RTX 3060 Ti AMP White Edition
With this new card, the brand offers us a rather compact model that is 23.1 cm long. As for the thickness, we are still faced with a model occupying two slots in your case.
This reference is displayed in white with a fairing and an immaculate backplate. Moreover, according to the visuals of the brand, the printed circuit remains black. Otherwise, this heatsink has two fans with semi-passive operation. They will blow on a large block of aluminum fins crossed by five heat pipes. Finally, a backplate is part of the game, however, the question remains whether it helps with cooling.
At the level of frequencies, we have the right to a small factory overclocking. Indeed, the boost frequency displayed is 1755 MHz against 1655 MHz for the card of NVIDIA. As for the frequency, no change with 8 GB of GDDR6 clocked at 14 Gbps.
We finish quickly with the onboard connectivity which is based on three DisplayPort 1.4a and a single HDMI 2.1. Finally, the power supply requires two 8-pin PCIe!
As for prices, once again, there will be plenty to choose from. On the other hand, Cybertek seems to offer it at the best price: 650€.
This way to the Zotac datasheet!
