2Way: a pink ITX bench at Sangyo!
Direction Japan where we can see a new bench table. The 2Way Bench Table mini-ITX Pink is intended for ITX configurations and has the particularity to be entirely pink. In short, finally a table that does not take too much space!
2Way bench table mini-ITX: a small bench table all pink!
2Way Bench Table mini-ITXWith this table, we find a product measuring 300 (W) x 215 (D) x 260 (H) mm and the weight is about 1.4 kg. Here, the choice of materials is 1.6 mm steel against 2 mm for the GPU support. As you can see, this model is only suitable for mini-ITX motherboards. For graphics cards, we have only two slots. Nevertheless, we imagine that triple slot cards can be installed on the table, but without certainty either.
For the rest of the components, this model has four slots for 2.5″ storage. As for the power supply, it will be able to accommodate ATX blocks up to 16 cm. However, this limitation on the size of the block is not a real problem, as it can be fitted to a 1200W in 14 cm now.
Concerning the cooling, we have an unlimited height for the CPU fans. On the watercooling side, we have rails positioned all around the motherboard slot for mounting the radiator. However, the maximum supported size is not indicated.
Finally, the table can be placed horizontally, like a table, but also vertically. Likewise, it also has a carrying handle.
To get it, you will have to turn to the Japanese Amazon and it will cost you ¥14923. With the conversion, this makes us ~115 €, beware of possible customs fees that may be added to the delivery.
