New case at Lian Li which announces the arrival of its 215 White. In broad terms, it is a black model but painted in white. Decidedly, between Phanteks and there, Lian Li, many cases come out in this color!
215 White : an all white case from Lian Li !
With this model, we find a medium tower case highlighting dimensions of 215 (W) x 462 (D) x 482 (H) mm. Here, the choice of materials is steel, glass and mesh for the front.
Inside, there is space to install motherboards in E-ATX format (28 cm wide). For the rest of the components, we find :
- Graphics card: 370 mm long
- CPU cooling unit: 166 mm high
- Power supply: 210 mm deep
As for the storage part, this case has an HDD cage with two slots. We can insert two 3.5″ units or a 3.5″ disk and a 2.5″ SSD. Finally, there are two small 2.5″ drives.
The cooling should not be outdone with the presence of two 200 mm mills in aspiration in front. Finally, a small fan of 120 mm completes the whole, at the back. Nevertheless, if you wish, you can install up to eight fans: 1x at the back, 2x at the top, 3x at the front and 2x on the power supply cover.
As far as watercooling is concerned, this 215 White is compatible with 360/280 mm radiators on the front. At the top, it will have to make do with a 280/240 mm radiator.
We end with the bill that will amount to 99.90 € for this reference. Also know that at this price, we have a fan hub and RGB with the ability to manage the lighting via a button accessible from the control panel.
Here is the technical data sheet of Lian Li (black version for the moment)
