A new case from the American manufacturer Hyte, which has announced the stunning Y50. This is a compartmentalized case featuring three tempered glass panels. But what sets it apart is its affordable price, which hovers around $100. Plus, it comes in unique colors like red, purple, and pink. To get an idea of what it’s like, you can always check out our review of the X50 here.
Hyte unveils its Y50 for around $100!
Compartmentalized design with three glass panels!
This case is a compartmentalized model with generous dimensions. It measures 288 mm wide, with a depth of 473 mm and a height of 461 mm. This results in a volume of 63.8 liters.
Internally, the chassis supports E-ATX,ATX,micro-ATX, and mini-ITX motherboards. It also accommodates models with reverse-oriented connectors thanks to the necessary cutouts in the main tray. As for other components, the case features:
- 360 mm in length and 170 mm in width for the graphics card
- 250 mm depth for the power supply
- 160 mm in height for CPU coolers
As for cooling, the standard configuration includes three 120-mm fans mounted on a single frame. These are mounted on the side of the motherboard. Finally, a fourth 120 mm fan is mounted at the rear. You can supplement this cooling by adding three 120 mm fans or two 140 mm fans at the top. At the bottom, you can install up to two 120 mm fans. As for liquid cooling, the case supports radiators up to 280 or 360 mm in size.
Priced at around $100:Â
As for the price, it’s officially listed at $99.99 on the brand’s website. This model is also available in several colors, including black, white, red, purple, and pink. In short, these are unique colors that offer a change from the classic black and white we see so often these days.
Check out the Hyte product page here!Â
