Good deal – AMD Ryzen 7 5700G for less than $200 on Amazon!
The good deal of the day concerns the small Ryzen 7 5700G from AMD. At the moment, we can find this APU for less than $180 on Amazon.
Ryzen 7 5700G: theAPU at a low price at Amazon!
AMD Ryzen 7 5700G
The test available here
On the menu, we find an APU signed AMD. Basically, it is a processor with an integrated graphics. This model has a CPU with a total of 8 cores with hyperthreading. It also has 4 MB of L2 cache and 16 MB of L3 cache. Regarding the frequencies, in maximum boost, it will reach 4.6 GHz against 3.8 GHz in base frequency.
In terms of graphics, we have the right to a RADEON Vega 8 iGPU with 8 comput units and 512 stream processors. This graphic part will not allow us to do crazy things, it is clear. However, if you play games that are not very greedy, it will clearly make the coffee. In MOBA, you can reach 60 fps on Dota 2 in 1080p with low details. Ditto on Counter Strike: GO, you can play comfortably.
Finally, we will retain a compatibility with motherboards equipped with an AM4 socket. Now, depending on the motherboard model (and the version of the Bios), you should be able to install it on boards equipped with 300 series, 400 series and 500 series chipsets. But to be sure, check the CPU compatibility!
As for the price, as we said, it will cost less than $178,61 on Amazon. An interesting model if you want to mount a PC without a graphics card for office use, multimedia or even light gaming.
Here is the Amazon good deal!
