EKWB, Slovenian brand known for its components for custom watercooling offers a new version of its AIO. Indeed, its Nucleus Lux D-RGB kits are now available in full white!
Nucleus : EKWB’s AIO kits are now white !
As a reminder, the Nucleus kits of the brand are available in two sizes of radiators: 360 mm and 240 mm. They have an aluminum construction and a thickness of 27 mm. Moreover, on this version, they go to full white.
Moreover, we find this white on the pump as well as on the fans. However, these elements benefit from aRGB lighting. On the pump, it is on top while the central hub of the fans is illuminated.
While we’re on the subject, let’s remember that the fans are from the EK-Loop FPT 120 D-RGB series. They operate from 550 rpm to 2300 rpm via a PWM power supply. At full speed, the airflow reaches 72 CFM while the static pressure climbs to 2.7 mmH2O.
Concerning the pump, no more details than that concerning its flow or its water column. On the other hand, we know that it will turn up to 3100 RPM via a PWM supply. Finally, its mounting is assured on the LGA-115x/1200/1700/2000 platforms and on AM4 and AM5.
For the prices, it will be necessary to count 171,32 € in 240 mm against 216,71 € for the 360 mm, the whole, via the store of the brand. This series comes in addition to the black versions and the Nucleus Dark !
Here and there the EKWB datasheets !
