The RTX 4070 GDDR6 phenomenon is gaining momentum, and after ASUS it’s Zotac’s turn to offer a whole series of cards! The brand is announcing a total of four cards, available in both black and white!
RTX 4070 GDDR6: four models from Zotac!
The cards themselves are not radically different from their GDDR6X counterparts. In fact, the cards are based on the original design proposed by Zotac. They feature a rounded casing with a two-fan ventilation system. The advantage lies in its compactness: two slots for a length of 236.7 mm. Normally, this should fit easily into any case!
And don’t forget that each model comes in two versions: one that makes do with NVIDIA’s reference frequencies, the other with a factory OC. This translates into a boost to 2475 MHz on one side, while the factory overclocked models benefit from a boost to 2490 MHz on the other. Well, it’s not amazing, but it’s still there.
Of course, the main attraction of this series is the use of GDDR6 memory chips rather than GDDR6X. This change has little impact on the card’s performance, as we said here. As for the price, expect to pay the same as for the original models.
Here are the Zotac product sheets!
