New motherboard from ASRock for the corporate world. The brand is unveiling its X600TM-ITX board, an ITX reference that comes with a host of different I/O panels to satisfy the widest possible range of needs.
X600TM-ITX: an enterprise motherboard for ASRock!
This new reference features a mini-ITX motherboard with an AM5 socket and an AMD X600 chipset. This model is specifically designed for Ryzen 9000, 8000 and 7000 CPUs, with a maximum TDP of 65W. As for the power supply, there are 4 1 1 power supply phases.
As you can see, this is a rather special board, featuring two DDR5 memory slots in SO-DIMM format. We’re talking here about a maximum capacity of 96 GB of memory operating at 6400 MT/s maximum.
What’s more, it has no PCIe slots, forcing users to exploit the processor’s built-ini GPU.
As for storage, we have two SATA III paired with two M.2 in PCIe 4.0 x4. Another M.2 in Key.E is present, but it will be used for a WiFi module!
Finally, at the rear, we’ll find a network driven by a Realtek RTL8111H chip and ALC269 audio. Depending on the variant, we’ll have either USB type C, DisplayPort video outputs, VGA outputs, etc. But in itself, nothing too transcendent. But there’s nothing really transcendent here, as ASRock isn’t adding an extra network chip, for example.
Pricing and availability are currently unknown.
Here’s the ASRock product sheet!
