On the Jonsbo side, we’re pleased to announce a new case, the X400 Pro White. This is a compartmentalized model with aluminum parts, a very attractive design and a neat cabling section with dedicated covers. In short, an attractive case.
X400 Pro White: a white, compartmentalized case!
Watch out for the clutter:
The main drawback to compartmentalized cases is their size. Indeed, they are very large, and this model, with its dimensions of 310.9 (W) x 460.7 (D) x 476.8 (H) mm, is no exception to the rule.
Internally, we find a motherboard tray compatible with ATX, micro-ATX and mini-ITX format models. It can even accommodate ATX models with reversed connectors. Otherwise, for the graphics card, we have 427 mm of free space in length and 176 mm in height for the CPU ventirad. As for the power supply, you’ll have to be careful, as we’re talking about a depth of 180 mm.
As for ventilation, we’ll be able to fit thirteen 120 mm fans, with two windmills at the rear to improve hot air extraction. As for watercooling, we’ll retain a 360 mm radiator support at the top as well as on the side.
The storage section remains fairly classic with the possibility of mounting a 2.5″ SSD and two 3.5″ hard disks.
Materials:
Jonsbo offers us a case with a steel chassis and tempered glass front and side windows. Aluminum is also used for the outer frame, reinforcing the impression of a high-end case. But the data sheet also mentions ABS plastic. In any case, this mix of materials contributes to proposing a substantial weight: 13.1 kg.
Price as yet unknown:
Price-wise, it’s still hard to say, as the brand has yet to communicate the price of this white declination. On the other hand, PC Componentes offers the gray version at a price in excess of €200. It remains to be seen whether the color will have an impact on the final bill, as is often the case.
Click here for the Jonsbo product sheet!
