Home News Hardware News D33 Wood: a wooden micro-ATX enclosure from Jonsbo!
Overclocking.com video
Jonsbo has unveiled its latest case, the D33 Wood, a new model designed for compactness. The case features a front panel with wooden accents, giving it an elegant design. The internal chassis allows for the assembly of high-performance setups with large graphics cards!
D33 Wood: a new case model from Jonsbo!
Jonsbo D33 Wood
This new case is a compact model measuring 238.2 (W) x 455 (D) x 368.4 (H) mm. As for weight, you won’t risk a backache when handling this model, since it weighs just 6.7 kg.
Inside, there’s plenty of space to install a micro-ATX or mini-ITX motherboard. As for the graphics card, it can be up to 435 mm long, spanning four slots, while there is 172 mm of height available for the CPU cooler. This case supports ATX and SFX power supplies, but in any case, the depth must not exceed 160 mm. Note that the power supply is installed vertically, lengthwise at the front of the case.
As for cooling, the D33 supports the installation of nine 120 mm fans: three at the top and bottom, two at the front, and one at the rear. Regarding watercooling, it supports 240 mm and 360 mm radiators at the top. These are impressive integration capabilities given the compact dimensions of this model!
Storage options are slightly more limited, as it will only allow for the installation of two 3.5″ or 2.5″ drives via a tray accessible behind the motherboard tray.
In any case, we don’t know the retail price yet, but it shouldn’t be long now.
Check out the Jonsbo product page here!
