WireView Pro: Thermal Grizzly launches its GPU power meter
A few days ago, Thermal Grizzly launched a new accessory with its WireView Pro. This is an interesting monitoring tool for your graphics card… It’s also a pretty cool 180° 12VHPW adapter.
WireView Pro: a little power meter for your graphics card!
The program features a tool that plugs into the 12VHPWR or 12V-2×6 socket on your graphics card. It features an OLED screen to display things like voltage, power consumption and current. You can also measure power consumption over 60 seconds if you feel like it, as well as consumption in Wh.
Of course, after the setbacks of this type of connector, Thermal Grizzly is banking on safety. On the one hand, it’s a well-built tool, but it also has an alarm when the temperature or current measured becomes critical. Normally, you should have enough time to switch it off before it goes up in flame.
We’ll also note two versions of the WireView Pro to match the normal and inverted connectors for your graphics card. Make sure you identify the type used on your card. Price: $76.19 direct from the Thermal Grizzly shop. This tool was designed by Thermal Grizzly and Elmor Lab.
Click here for Thermal Grizzly’s product sheet!
Click here for our WireView test (non Pro)
