Watercool Heatkiller V Pro for the RTX 4090
New waterblock for graphic cards. This time, we are not interested in an EKWB model, but in Watercool. The brand announces indeed, a Heatkiller V Pro for the RTX 4090 Founders Edition. The latter is available in black or white!
Heatkiller V Pro : a waterblock for RTX 4090 from Watercool !
Watercool Heatkiller V ProWatercool offers us a new waterblock which will be a full cover type despite appearances. Indeed, the RTX 4090 from NVIDIA has a short PCB, which justifies the dimensions of 220 (L) x 124 (W) x 32.8 (H) mm with bakcplate and terminal. Moreover, thanks to this block, we will have the possibility to upgrade the card to dual slot format!
Otherwise, this model is based on a nickel-plated electrolytic copper construction. The upper part is made of anodized aluminum and plexiglass for the central window. Finally, we can count on an acetal terminal.
You should know that this waterblock is supplied with a number of elements. In the box, you’ll find the block, a backplate, mounting hardware, a syringe of Thermal Grizzly thermal paste and a double slot bracket.
For the price, it will be necessary to count 249,95 € directly on the site of the brand, and this, for the black or white versions.
Here and there the technical data sheets of Watercool !
